Motor Interchange
2002 MazdaSpeed
Can you guys confirm that a 2002 Mazda 626 2.0 is interchangeable with a Protege 2.0. I need to buy a new motor and the 626 engines are considerably less from a junk yard than the Protege.
Thanks
it will fit but you will have to swap the intake manifold, valve cover, thermostat cover, heater bypass pipes, the coolant junction block, oil cooler, and the MBSP over
