Motive Bleeder for Mazdaspeed 3
AlpineFD
Just wanted to give everyone a heads up, I found that Motive Product's 1109 adapter is a perfect fit for our Mazdaspeed3 mastercylinder.
motiveproducts.com
You are looking for the 1109 Black Label European adapter
With this pressure bleeder, I can pressure bleed my brake in 10min !
If you haven't heard of this bleeder before, basicly it connects to your master cylinder and pressurize it to about 10psi via pumping action, then you just loosen the bleed screw as usual, easy effective 1man bleed job =)
