H3b,
I do not plan to drive at nationals.
I did do the Salina div and the couple that run the Cobalt with slicks said there is a MS3 in Lincolin that is running slicks with stock shocks. Is that you?
I do plan to go to Nationals to learn.
Currently I have set up 1/8" toe out but my alignment guy said there was no more negative adjustment. This being my first time messing with alignment did not press the issue.
I am currently running Re-11's 235/40 18 stock wheels.
H3B if you are running what tires do you use and what size?
Thanks to all.
