If you must turn up the boost, I would only go 2-3psi above stock.
Has anyone installed a boost gage on a stock car without a MBC?
What are they running.
Remember, this car is a tunned na engine. It is already above what stock was. I'm afrade to get the truth, you will need time. Another reason I want to keep my car stock. I'm getting it for the way it handles, now how fast it can go in a streight line.
The car I tunned has already had a decade of people figuring crap out. This car is new and I can't imagine there being a expert on it.
The turbo: The Garret T25 is a fast spooling turbo, but is not a top end puller. It is the same turbo used on the Eclipse, Talon 2G. It falls off on top end. However, that was on a 2G that ran 12psi stock. If the MSP runs 6 psi stock, the stock turbo should be able to hold it to red line. So if you add 3psi, can the stock turbo hold full boost to 9psi on top end? Does the stock injectors, and fuel pump flow enough for 9psi to red line?
I myself would wait for information about what the engine can do before turning up the boost.
A intake, larger IC and piping, and exhaust work is probably the safest upgrades you can do. While a boost controler and boost gage are the cheapest, it might not be the best. Also, the stock exhaust size doesn't suck. The best thing to do is add high flow cats (if you want a stock look) and maybe a better muffler.
The upper IC pipe isn't small. The IC isn't tinny winny, so if it flows as well as the upper IC pipe, it should flow enough for anything under 10psi.
If you want a fast ass car, I don't think a MSP is the way to go.
