Wiggles422
- MSP #654
Anyone else have a hard time imagining going 15,000 miles without an oil change? I'm a little skeptic. What about the oil filter? Would you have to change that at normal intervals?
Wiggles422 said:Anyone else have a hard time imagining going 15,000 miles without an oil change? I'm a little skeptic. What about the oil filter? Would you have to change that at normal intervals?
AFaceInTheCrowd said:uhm... i just recently changed my synth at almost 4k and it was black as night. did NOT look ok to me.
Protege52003 said:my father seems to go 10k with dino oil on most of his cars and has never had any engine trouble.......just makes sure he keeps it full. i am sure synthetic is good for 15k. when i change mine between 7-8K it still looks pretty good.....
believe you are supposed to change the filter in the middle of that 15K?
tyusha said:Hey, Ryan, do you change the filter during those 7000 miles or you still use the original filter you put in with the oil change?
mokeOne said:i'm using that new mobil1 in my p5 with a fram filter. the oil still looks pretty clean on the dipstick, so i'm pushin the change. gonna stick to changing filters every 3000 like i always do though. i'm also running an aftermarket oil cooler, so that might help out with oil longevity. (thumb)
Protege52003 said:i use the same combo.....but i belive it is a waste to change every 3k with you P5. the synthetic oil is made to go way longer than that. stick with dino oil if you are going to do it avery 3K.....
