2007
ok guys anyone have any ideas? well this is my little problem i have been getting a misfire 4 cylinder. now at idle i get a rich spot. does anyone know the symtons of a bad fuel injector.
is that it plz chim in all input welcome
i posted n other forums
Hey guys any ideas well had some fuel pump issuse i have a stock pump in now. i was getting a cylinder 4 miss fire i did a compression tell across the board 155- 160 psi. looked like plugs were bad so i changed them out with bosch platium 2 the auto stores dont have the one step colder denso i was using. i did put injector cleaner in i will post to logs if any one sees anything up with them chim in ok thanks for all the help
