I just want to add I did this to our P5 this evening. Not sure if anyone else has done what I did, but I took my air nozzle and blew it lightly in burst into the feed line out and return on the pump. Not sure which one it was but one of them spewed out a thick nasty crap of dark brown and black. I did it until nothing came out. I almost want to suggest this to others, however do it with cautions, you don't want to blow out a seal or anything. Works like a champ. I picked my strainer up from advanced auto for $9 which was in stock.
As for the work itself, the bolts were all rusted to horrific proportions. I used a few tools to remove them. First was my impact driver. Worked bery well for most. A few were too far gone. I then used the pointed pic. I hammered straight on the side to give it a dimple, then cocked it sideways a tad and tapped until loose. All came out with minimal effort. The tops were rusty, however once they broke loose they came out with my fingers. I also sprayed the car with a pentrant and let it sit for about 15 minutes to absorb. I tried using bolt extractors but had no luck, they just ate the heads round and smooth. Those are the ones I had to use the pick for. If I would have went straight for the impact driver I honestly think I could have gotten them all out. Also side note for those who have never used one....1, they are pretty cheap at sears 2, you have to give it good blows for it to work well.
-Keith
