hedlesschkn
- 2002 Mazda Protege5
okay, i have been searching through the forums for several hours on several different occasions so i have decided to post a direct help to my specific problem since my situation doesn't seem to quite relate exactly to some of the other posts.
the story:
bought my car with 75k on it, drove it for a week and it started misfiring on the highway, i pulled over let it sit it started right back up not problems, cel turned itself off shortly after. several days later i start my car, drive for a while turn it off, go to start it up again while warm and it misfires like crazy sputtering jerking flashing CEL. let it cool down, start it up and it runs fine so i drive her to autozone and get the code read p0300, random misfire. searched the forum and did a few suggested things (see below) i ended up cleaning the EGR valve and oiled it with wd40, seemed to do miracles to my car, ran better than before, idled more stable, better response, etc. could not get the car to misfire at this point. (tried starting it cold and warm, starting the engine via turning the car off while moving and then letting back off the clutch) car ran fantastic. i just drove 500 miles to school, and then drove the car for another few days up here with no problems. today it starts misfiring again. my dad suggests cleaning the egr valve again and using something better than wd40 to lube it so i do (used brake-kleen as suggested to clean and 3in1 oil to lube as suggested in the how to). car runs amazing again, i drive maybe a half mile, go to a meeting on campus for an hour or so, go back out to my car and it misfires again when i try to start it. so now ladies and gents, i am here begging for you help to solve this issue once and for all.
things tried:
-pulled the fuel pump made sure the fuel sock was clean (looked clean but i cleaned it more anyways)
-pulled the spark plugs, checked for corrosion, spacing, and burn marks they look almost new.
-checked the resistance on the plug wires according to the user manual, seems fine
-cleaned the EGR valve... twice
commonly asked:
"is there smoke" - not that i notice
"does it knock or ping, any metallic noises" - no just misfiring and studdering / shaking
"did you replace the coils" - not yet, wanted to confirm that it could be the coils even though sometimes it runs fine and other times it does not.
"cracks in the hose that goes into your block from the intake" - looks crack free, note: i have an aftermarket cold air intake
any help would be greatly appreciated, thank you all in advance!
the story:
things tried:
commonly asked:
