Millenia OBD II fuse
Mestopin
I keep getting an ERR on my OBD II reader. I believe I may have blown a fuse in the system. Can anyone tell me if the OBD II connection has a fuse link and where can I find it?
I've looked in the fuse box but there is nothing that is identified as an OBD fuse. Maybe it's inline or under the hood? I've checked the wiring and it appears to be good.
I have a 97 Millenia L.
Thanks for any help.
if the fuse to the computer were blown the car would not run.
What type of OBDII reader are you using? it has to be compatable with Imports/chrysler cars, one for GM and Ford will not work.
There is no inline fuse on the plug.
I'm using the TP150. It's one I got off ebay for $40 or so. It reads my Liberty fine but apparently doesn't like the Millenia.
When I first used the reader I had to jam the plug into the connector because of poor manufacturing. Maybe I screwed something up which is why I was hoping for a fuse solution. But if there is no fuse then maybe the harness or wiring needs to be replaced.
Anyway to check this?
