RaiderMP5 said:tough to say without looking at the top/bottom view. It sure does seem like it though. Here is a pic post install.
What kind of header do you have?
RaiderMP5 said:I have a Ractive header. I had a local shop throw in the 2nd bung for $25 bucks. Not too happy with the angle, but I have not had a problem with it at all.
RaiderMP5 said:use both. Drill one out. Use a dremel or 1/2 drill bit on one of them, screw that one onto the o2 sensor, then screw the o2 and drilled non fouler into the non-drilled non fouler, then screw them all onto the header.
i12drivemyMP5 said:ooo, scary. Does the angle of that o2 bung make the sensor stick down below the car so that it grabs trash on the road? Mine is right after the bend pointing horizontal to the ground towards passenger side of the car.
ENTENSE said:aahhh, gotchya, Now that should eliminate the check engine light.
BBSF2 said:your second 02 sens or might also be bad or dirty. i know that when i had my mil eliminator in, it worked fine for a while, but than i got a cel. it said no activity, so i swapped the sensor out to a new one, and have had no problems since. the mil eliminator i used was from pony express performance. that is my idea.
FasterP5 said:... I really hate to bag on anyone's products, but when there is consistant
evidence of difficulty, I'll put in my $0.02:
Tried the Pony Express Mil Eliminator twice
- first time it came on after 250 miles or so (reset, repeat)
- second time it would come on after every 500 miles or so (reset, repeat)
Both times I VERY CAREFULLY soldered all connections on the bench
(these were SOLID solder connections, I would highly doubt that there was
any problem with my soldering job)
So I had a muffler shop put in a new bung behind my cat, got another
O2 sensor, soldered in enough wire to extend it to behind the cat, and
no more CELs (for 30K miles so far).
