Guys..you should read up..on the egr..thing..
[font=verdana, geneva, helvetica]Definition: The EGR valve is the main emissions control component in the exhaust gas recirculation system. The valve is located on the intake manifold, and opens a small passageway between the exhaust and intake manifold to allow a metered amount of exhaust to flow back into the engine. This reduces combustion temperatures and helps control the formation of oxides of nitrogen. The EGR valve is opened by the application of vacuum to its control diaphragm. Some also require a certain amount of exhaust back pressure before they'll open. On newer vehicles, the valve is electronic and uses one or more solenoids or a small stepper motor. The valve should remain closed while the engine is cold and at idle. It should only open once the engine has warmed up and is running at part-throttle. If the valve sticks shut (or is disconnected), NOX emissions will soar and detonation will often result (See Detonation and Spark Knock). If it sticks in the open position or fails to close all the way, it acts like a vacuum leak resulting in a rough idle, hesitation and possible stalling. [/font]
