megan catback
I am very happy with mine. Like with any exhaust system, usually you have to tweek it around a little bit to get the clearance. Get some stiffer hanger grommets from the autoparts. Oh yeah motor mounts definately keep it from moving around so much.
Motor mounts look like the trick. Video as promised. Look at the muffler moving around - that's all coming from engine movement. The "smoke" is because I didn't let it warm up all the way.
That sounds good.It is just a little deeper than mine. Do you have headers on your car? I have OBX headers and am trying to take out the 2nd (last) cat.
Nope. Everything's stock except the cat-back.
I appologize for those of you that are tired of seeing this thread come back, but I need to vent. You can catch up on the history on this thread and here: http://www.msprotege.com/forum/showthread.php?t=123623489.
I'm getting too old for this. Mine got to rattling pretty badly so I decided to go ahead and work on the heat shield. My plan was to mark where it was hitting, remove it, cut clearance holes in the sections that hit the exhaust, and then spray it down with rubberized spray (I found some at Wally World). Jacked the car up and loosened the 4 bolts holding the heat shield on. So far so good. I got two of the bolts out and started working on the other two. All of a sudden while turning, it got too easy. The short of it is that the bolt screws into a nut that's tack-welded (or glued for all I know) to the underbody sheet metal. The weld broke leaving me with a spinning nut and no way to hold it. Ditto for the last bolt. I was pissed. Nice work, Mazda - crap engineers (and I've been an automotive design engineer for 7 years so I can say that)! Good thing you saved those 3 cents. Ended up having to tear the heat shield and slip it off around the bolts, which are still hanging from the underbody of my car - I can't take them off or tighten them. I guess I'll have to dig through the carpeting and such in the floorboard to see if I can get to them from the topside.
Anybody want to sell me a heatshield cheap? Mine's trashed.
Anyway, I went for a drive to at least enjoy the pure unclanging sound of the exhaust for a change and everything was a little more cheery. I do love the sound when things are right. After a 15 minute spirited drive I pull into my driveway, pull up the parking brake (yes I prefer a manual transmission AND I use my parking brake), and get an earful of clang clang clang. Get out and trace it down to the fact that now the rear pipe is banging into the rear subframe! This sucks. I also now notice an exhaust leak at the front connection to the cat where I had to improvise a gasket because Megan Racing couldn't bother to provide 3 instead of 2 (yet another dollar saved).
I have 3 kids under 3 and don't have time for this anymore. Should've left my car stock. I think I can adjust everything to get rid of the subframe problem and try again with the cat gasket, but I'm tired of climbing under this thing at night after the kids go to bed. At least it's in the 70's so I'm not freezing my knuckles off.
Hopefully y'all have more time energy than I do. Otherwise, don't bother installing this exhaust.
Dang that really sucks. So far I haven't had any problems with the heat shield screws and I just went and grabbed another exhuast gasket from Pep Boys. As far as the exhaust hitting the rear subframe, I haven't had that problem.
Should've left my car stock........ I'm tired of climbing under this thing at night after the kids go to bed
Wan't to sell it? I would be interested.
No, unless you want to give me a small fortune for it. I like the car too much and I'll be able to work out the bugs. Actually I haven't heard the exhaust hitting the subframe since that last post. And I think I need to get a 2" gasket for the cat connection instead of the 2 1/2" one I got last time. I just used to love this stuff 10 years ago - now it's too much like work.
only meant the exhaust......glad to hear that it is getting better.....hope it all works out
I had the same rattling with my exhaust. I played with my Megan for about two weeks straight until it was positioned just right. Stiff motormounts helped and I also put cable clamps over the rubber hanger grommets to hold the hanger a little more firmly. No complaints for half the price of the other catbacks.
I definately agree with the I'm getting to old for this stuff too (34, but it's that stay young at heart thing). Turbo kit install, clutch coilovers, and tranny replacement among many other things by myself. But I just keep on going for some reason.
