Medieval Motor Mounts (Bushing Replacement)
Well Red Bushing (1.5" from AWR) is too small for the passenger mount and the Black 2" is too big. This weekend I will be removing the transmission mount unless the 2" bushings fit. (which at a glance looks like it isnt going to work) If it doesnt work I will be swapping back to OEM until I find a suitable replacement. Until then I am out $60 on these AWR bushings.
I would just make one or a few actually if i had the money. what you need would be
small vaccum pump
mold
small vaccum chamber in order to pull bubbles from poly mix in mold
done
I am looking for replacement bushing for my front rear and transmission mounts.
These look promising ->
http://www.energysuspensionparts.com/Energy-Suspension-Universal-Link-Flange-Type-Bushings.asp
I am also thinking of doing what CHIQLES has done and just use the universal bushing in the oem mounts. for the two side I will use the liquid kit.
CHIQLES what was the size or part no. for those universal bushing from energy suspension?
These look good as well ->
http://www.energysuspensionparts.com/proddetail.asp?prod=9.4102
