Just installed a joe p xz mbc. Took it out for a test drive and slowly turn it up when we find out what boost we're hitting. We're getting right aroung 8.9 lbs of boost and while we're in 3rd gear right around 3500 rpm there is a violent buck Then the boost drops to around 8.3 lbs. It bucks every time. I thought fuel cut was at 9? We are running a blitz duel turbo timer boost gauge. Basically .60 hkpa, then we multiply that by 14.7 to equate the psi. So when we hit .60 hkpa it drops down to .55 wich is 8.0 psi. We just don't know what's going on. We have the turbo timer is hooked to the small line that runs to the blow off valve. Thanks for your help.
