Mazdaspeed Vs Integra
ok well if you want cheap hp then id suggest buying a srt4 neon stage 3 it with toys for $3500 and your at 355 reliable streetable hp.
look... msp's are great... they are just... PICKY... my ecu adapted to changed i made in a day... that is so frustrating... put intake on an integra.. and tehre is instant change.. and it stays taht way.. put intake on an msp, or p5... and the ecu adapts to it and if it dont like it your stuck in limp dick mode... eh.. do what you want with what ever car... just dont loose image of what you want to do with it... no matter what car you get... hell itis a car.. and they beat walking.. ( most of the time.. ) good luck man...
i'm not so sure our ecu does what you say it does. but i do know the Cobalt SS/TC does indeed adapt to counter mods unless you get ems and a tune.
it does, to some degree at least, it will learn around an Apex-i SAFC as well.
actually that i have heard of. and that would explain why nobody runs it. however i have read that the ecu cannot learn around the SS AFC so that's all i care about. but i think it somehow learned around mine...or maybe that's because it's still not installed yet (shrug)
yeah, you can put clamps on to stop it from learning around it... but the SSAFC or unichip is a far better plan.
if its not installed, it'd be hard to learn around!
i actually meant because the car is still running bad as opposed to how good it would run with the AFC. but this is all understood so i'm not sure why i'm typing it.
just send it to me... then it won't be wasted not installed. I'd have that thing in yesterday, if only to save some gas!
lol it's all my dads fault because he's supposed to get some fittings for my vacuum block so i can actually plug in the hoses to it...and then install my whole vacuum hose kit...and then install the SS AFC into the vacuum block. it's always something that holds me up.
i like the idea of the new genisis coupe 4cyl turbo. i know its off topic and barely related but its rwd, has the same engine as an evo and will have tons of after market support.
