Mazdaspeed Ms3 springs
fsd_619
2008 MazdaSpeed3GT
Hey guys i want to lower my speed3 and not void my 7year warranty. I know these springs will not lower the 3 a lot but there the only ones that wont void my warranty. i would like to see a picture if anyone is running the mazdaspeed springs.
Thanks in advance
The aftermarket Mazdaspeed springs for the MS3 lower the car a good .5" and make the ride a bit firmer. As for your 7 year warranty, the springs will shorten the life of your shocks regardless. So I really wouldn't worry about warranty if you get aftermarket springs.
Mazdaspeed springs
Here's my Speed 3 with the mazdaspeed springs. I used the stock shocks and after about 25k miles (including two trips to the Dragon) I will be replacing the shocks. Not a huge drop but the handling difference is quite evident.
anyone know what the stock spring rate is vs the MS spring rate ?
I've been towing a lot and want to get stiffer springs atleast, don't care about ride height that much, would rather keep ride height as close to stock as possible.
