MazdaSpeed CAI intake Filter
fu1276
itz the time for me to clean my intake filter. If i put an AEM Cold Air Intake filter on my MSP intake, do you think that's gonna fit?
you need to measure the amount of room that you have for clearance, you should be able to tell after that.
all the standard openings on the filter should be the same 3.25 unless the person had a cobb then NO it's 4.5 it will not work.
Will AEM Dry work on the CPE Nano?
Yes it will, just make sure you buy the one that's almost the same size and you will be just fine, and when I say the same size check the length, ID of the opening and the circumference of the actual filter to make sure it will clear the hood. If I recall it's 3"x 5.25
