Mazda5 correct Alignment Specs
rhayan911
Hi guys, just wondering what is the correct alignment specification for Mazda5? recently I'm having a severe tire noise on front end like the tire is scraping the road especially on slow driving, more noise at front passenger side wherein like all the weights are their, and it's hard to find the "0" position of the steering wheel. After having a tire rotation it creates much loud noise. and when I check the tire the front is having a wear on the outer side, and the rear tire having a wear on the inner side. dealer said alignment are in specs.
here are the data they gave to me:
FRONT:
Camber: Left = -0.8 deg.
Right = -0.9 deg.
Toe: Left = 0.00 deg.
Right = 0.10 deg.
REAR:
Camber: Left = -1.5 deg.
Right = -1.6 deg.
Toe: Left = -0.05 deg.
Right = -.05 deg.
Thrust angle = 0.0 deg.
Setback: Front & rear = -0.1"
Are this numbers ok? I'm still thinking why the tire create the scraping sound if it's in specs? thanks in advance guys.
Specs:
Front
Toe-in: Tire 2mm +-4
Inner rim 1 +-3
Caster with 1/2 tank of gas: 2.9 degrees +- 1 degree
camber: -0 degrees 41 minutes +- 1 degree
Rear
Toe-in: Tire - 3mm
Rim - 2
Camber: -1.25 degrees +-1 degree
help please - excessive tire noise
Thanks, right now I'm really having this loud noise coming from the wheel running at slow speed. sounds like groaning/grinding noise especially when decelerating. really confuse what create that sound. like their is a worn suspension part that related with the excessive tire noise. need help with this one.
Your suspension joints are 'creaking' or wearing or your wheel bearings are going out, have both looked at. Also on the 5 top of the strut is about 50 small bearings that allow the strut to rotate, if they are dirty they will make a grinding noise. Hard to diagnose over the internet, so we'd need more info, like what happens when... What speeds... Year of M5... Miles... Tire size... any mods done... everything stock? (peep)
Peace!(rei)
I got 2009 Mazda5 (touring) with 27,000 mile. everyday use for long trip. all are stock. but their is one time that I try to use 16" mazda6 oem wheels. but after 500 miles I return the stock. Their is also a squeaking sound underneath the front end going on just on Speed bumps. at a speed of 20-40mph you will hear loud sound like rubbing. like the tire is rubbing against the road surface. when running at highspeed about 50-80mph the sound still their but a little bit lessen. you will just hear a cyclic sound. this noise is just in FRONT. mostly in RIGHT FRONT. steering has been affected. having this pull, wherein its hard to find the "0" position of the steering wheel. tires already got uneven wear, tire at the back wear just at the inner side of the tire, on the front the outer side is wearing. when I rotated it the noise gets louder. I told dealer about that but the alignment are ok they said.
I'm just wondering if the alignment specs they made to my 5 is good. because the angle of the wheel is really noticeable. especially at the rear.
hope you guys can help me. thanks
That is newer car, so has it been in an accident?
That could be the problem, when those rims
and tires where on there, it might have stressed
out your joints and caused irreplaceable damage
to the joints, did the guys that did the alignment
look at those joints?
Also, the M5 has no rear camber adjustments,
they are ALWAYS camber in (or negative camber)
Okay that is one more tell tale sign that youre
steering and suspension joints are toast. I bet
you need to get them replaced.
Also see if youre having the engine mount
problem described by others, there is a
thread about the engine mount boots going
bad around that many miles.
Not to be a smart ass, but the tire
always rubbing the road, otherwise
youre flying ! LOL! (lol)
So again hard to do over the internet,
ask if one of the mechanics from a shop
or dealer can ride with you and you can
get the car to make that sound.
That is because those joints
are not being flexed as much,
but are flexing a bit more
repetitions per cycle. You
need to take a mechanic for
a ride (cabpatch)
Okay, yes now we are getting
somewhere; that is definitely
your rocker arms, joints, suspension
and alignment all in play. Go to a
VERY REPUTABLE repair shop, one
that is expensive to start, because
what youre talking about is a
combination of things and some 17
year old summer hire kid cannot fix
your car problems in a 30 min oil
change at jiffy lube.
Crap sounds like that car
has been in an accident?
Did the wife hit a dear or
curb really hard? LOL! (wink)
BINGO! Because there is more
tread on that tire, now that
joints and such are going to
sound more because theyve
not worn down the tread
enough to quite down see
what youre describing is
TWO things are fighting.
The tires are TRYING to keep
the car aligned, but some boot,
joint, arm, bar, whatever under
there is not right, so they fight
against each other. (boom03)
That is because there is no
weight on the rims and tires
when its up in the air. MAYBE
the body is crooked. Theyd
need to check the frame alignment
and that is expensive. Did you buy
this used?
If not used, I take it back and get
my money back or trade it in and
get another car? (j/k... or am I?)
Specs = got to go look it up yourself.
Rear = There is no camber adjustment
in the rear of the five, so that wear on
the back is from:
1. The way the car was built
2. Your rear strut(s) are going bad
and cause more negative camber
THAN THERE SHOULD BE.
Well try, but YOU have to work
on this too, go do these things
and/or keep us posted as things
get looked at.
As for the alignment, you'd have
to take it to another place and
see what they recommend, I don't
have the spec sheet for the 5.
I thought someone else would chime
in by now with that.
Good luck!
Peace!(rei)
Thanks SGT_OKINAWA! I Got my 5 brand new. I remember that I hit a curb before but not that hard. not been in accident. I will bring it to the shop and let them check my ball joint. I remember that their are times that it makes a knocking sound, not a regular sound. I suspected before the strut valve in front. but the already replace my strut & rear shocks. they already check all bushings. but as you said the I will try them to look at my ball joint. or frame alignment. I will update you for this. this is really helpful. thanks again.
I know this post is old, but the issue here is a tire, not suspension. The cyclic sound is more or less a separating belt inside the tire(s). Lots of the Toyos on the 2006 models had the issue; not sure about newer model years. Buy new tires and it'll go away. The sound changes as you rotate tires because only one of them has a problem. The sound will get worse as time goes on and the tires wear more. Been here, done this, fixed it (new tires).
New Threads
