Mazda5 (2017) Brake lights do not work after battery change
Hello folks,
After battery change 2 out of 3 brake lights do not function. Top-central LED strip works as required, but 2 main brake light (left and right sides) do not work at all. Bulbs are ok'.
Any idea or recommendation will be appreciated.
Can it be the fuse or brake switch if one of the brake lights still works?
Shouldn't be the brake switch. That's causing the one to work. Your first instinct is right, check your fuses.
