Mazda3 showing "Vehicle System Malfunction" but nothing specific
2023 Mazda3 GT FWD
Randomly started getting this today and it seems like it's persistent. Drives fine, nothing seems out of ordinary.. just have that warning light. Mazda App also not showing any error codes in my inbox.
Recently did the transmission relearn thing from here:
and that made my transmission more responsive because it was previously a bit laggy. Also I have fuel milage around 13/14L / 100km which seems a bit high. My car has around 7700km on it and mostly city driven
Thanks
Any suggestions before I bring to dealership, i'll be going but they cant get me in till a cpl weeks. I also ordered an OBD2 scanner... to check for codes
edit: Also I have a dash cam hardwired to the fuse box from 2+ weeks ago, not sure if that would cause this
Maybe it's the battery. Try removing your cam wiring.
Car Scanner ELM OBD2
Version: 1.114.0/401140/GP
DTC report
Connection profile: Mazda SKYACTIVDate: 2025-04-06 6:01:37 PM
OBD-IIOBD-II
DTCs: 1
P05A0(00) [0x05A000]
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
Engine control unitEngine control unit
DTCs: 1
Transmission control unit
No DTC found.
ABS control unit
No DTC found.
Dashboard
No DTC found.
BCM
No DTC found.
Steering
No DTC found.
Adaptive headlights
No DTC found.
SRS/Airbag
No DTC found.
DCM
No DTC found.
Multimedia
No DTC found.
I'm getting a P05A0 DTC :O
If you say there are no DTC found, check the windscreen in front of the video camera ( forward sensing camera) for the traffic sign recognition system, it could be dirty. Check the radar sensor, maybe the badge is cracked, maybe a wire disconnected. On a second thought, where did you mount that video camera of yours? Behind the centre rear mirror? Access those panels and check for connections, maybe something is disconnected.
I'm confused. You stated "I'm getting a P05A0 DTC :O"?
Yeah thanks guys. I am getting a DTC: P05A0(00) which googling means something wrong with the Air shutter grill? I took a look through the grill today and i see some leaves and stuff in there. I'm still going to take it to the dealership coz im still under warranty but hopefully cleaning it out fixes it
also I noticed i am getting much worse (average) gas milage recently: like 16/17L / 100 KM so maybe they are stuck or something.
