Mazda3 Fog Lights
racerboy777
Mazda3i Touring
I just got some OEM fog lights for my '06 2.0 and wanted to know if I HAVE to remove the front bumper to install them? I'm prepared to do so if required, since i had to do it for my HALO's. If I do then I will just remove the resonator while I'm down there. But just wanted to know if it's mandatory to remove the bumper?
Thanks
Josh
(glare)
The How-To section was put here as a repository for people to post procedures for work they have already done to their cars and wish to share the knowledge.
If you have a question about how to do something to your car,
POST IT IN THE APPROPRIATE FORUM!
If you have an appearance-related question, post it in the 3/MS3 Appearance forum.
If you have an engine-related question, post it in the 3/MS3 Engine & Performance forum.
If you have a question about electrical or audio, post it in the 3/MS3 Car Audio & Electronics forum.
If you have a question about wheels, tires, brakes or suspension, post it in the 3/MS3 Suspension, Rims and Tires forum.
Your cooperation is appreciated.
Don't know the answer but would be interested in hearing how to install factory fog lights.\
Racer, do you have the factory grill replacements and everything to make it seemless? If so where did you find them? Does it all come with the fog lights? You must have to then mount a different switch inside, I mean different than the factory.
You sure are bossy for being on your 8th post, aren't you?
if you bought the original mazda parts the foglight and the cover comes as 1 unit. for the fogs u dont have to remove the bumper. get the nose of the car up on some ramps, the the underside there should me plastic flaps on each side. you unscrew those (i think abbout 3 screws starting from the outside and working your self in) and just pull them back. you should have enough room to remove the plastic cover and replace it with tha fogs. the connector is just right there too.
