M Markmazda3 Feb 6, 2024 #1 Hey new here. Wondering if the coolant reservoir for the 2.5 liter is the same as the 2.0 liter. My 2.5 tourer has a pin hole in the bottom. Tia
sm1ke 2022 Mazda CX-9 Kuro Edition Moderator Contributor : Canada Feb 6, 2024 #2 What year is your Mazda3? EDIT: Check here. It appears that the coolant reservoir for the 14-18 Mazda3 works for both the 2.0 and 2.5L. Mazda OEM Engine Coolant Reservoir Part# PE01-15-351A | OEM Vehicle Parts OEM Mazda Part # PE01-15-351A - Engine Coolant Reservoir Fits 2013-2023 Mazda Models: Up To 35% Off On Every Order And Guaranteed Fit When You Enter Your VIN www.oemvehicleparts.com Last edited: Feb 6, 2024 Upvote 0
sm1ke 2022 Mazda CX-9 Kuro Edition Moderator Contributor : Canada Feb 6, 2024 #4 Markmazda3 said: 2010 Click to expand... Mazda OEM Reservoir Tank Part# L3CE-15-350A | OEM Vehicle Parts OEM Mazda Part # L3CE-15-350A - Reservoir Tank Fits 2010-2013 Mazda 3 Models: Up To 35% Off On Every Order And Guaranteed Fit When You Enter Your VIN www.oemvehicleparts.com Upvote 0
S Sonew1982 Feb 27, 2024 #5 You can also try to seal the hole temporarily with epoxy or silicone, but this is not a permanent solution. small world cup Last edited: Feb 27, 2024 Upvote 0
