Mazda2 1.5 supercharger Project
2009 Mazda 2 Turbo
Mazda2 1.5 Turbo Project
Hi my name is Luis and my car is the Black M2
I'm from Panama like Matrixxx
I'm planing to add a Eaton m45 from a Mercedes
Right now I have the supercharger
Intercooler (24x7x2.5)
HKS BOV or ByPass
AEM F/IC-6 PiggyBack (30-1910)
The only thing that I need to begin the assemble is the ECU PIN-OUT or Wiring Diagram to know where I have to put the wires of the AEM F/IC
If any one of you know where I can find it
I appreciate any help that you can give me with de diagram or any thing else, because I will need all the tips and knowledge that you have
you really dont need an intercooler with a supercharger but since you already have one it wont hurt, good luck on the project!
Halo Piocas
Give me some time to contact to the turbo mazda2 that uses the AEM ecu and i will answer you about the ecu pinout.
In the meanwhile you can start designing and making the compressor's mount with which you will attach it to the engine block.
Thanks for your help, but I'm stell need others pins like TPS, CRANKSHAFT
POSI, CAMSHAFT POSI, O2 SENSOR and INJECTORS
Bless
Continuing with the project, I must inform you that I will not use the supercharger
My mechanic told me that it is possible to install the supercharger, but the
space to install it is very small and could have problems.
For this reason, I decided to install a turbo.
I will use a Toyota CT12, which came in the Supra twin turbo and a External Wastegate with a 6psi spring
piocas, de esos pines q ya tenemos alguno me servira para cacar la seal par un shift light?
(any of these pins that we have some work to get the signal for a shift light?
update of the project... first home made ms2 of latinoamerica (lurk)
Hi vdsracing
Matrixx will post the photos later
The car have a custom exhaust manifold
Turbocharger Toyota CT-12A from a Supra Twin-Turbo 1JZ
External Wastegate at 6PSI (0.42 Bar)
AEM WideBand
Koso Gauges
O.Z Ultraleggera Wheels 17"
Injectors from a mazda6 2.3 N/A
Front Mount Intercooler 24X7X2.5
2.25" Intercooler Pipes
HKS Blow Off Valve
Greddy Style Oil Catch Can
2" Exhaust pipe
OEM MazdaSpeed3 Exhaust Muffler
AEM F/IC-6 (Not installed yet)
I'm registred in the MRS-Racing forum, but I dont know how to create a new post (I do not understand the Chinese symbols)
I want to talk with them, to see if they can send to me, how to install the AEM and propper setting.
If you could talk to them would be great.
Ok my friend,I have already asked him for further info.Waiting for his answer.
Post pics and videos imediatelly!!Many pics!!(bump)
so you currently running the turbo on the stock ECU?? what A/F ratios are you running like that?? we need under hood pics that is such a sweet little project. Any idea how much power your producing?
In this moment I'm on ride mode.
The boost gauge have a warning light that I have set on 0.5 psi
When the warning light is on. I get off the gas pedal
The stock ECU work on Closed-Loop. the AFR remain on 14* even with the bigger injectors
for this reason I need to know how to install de AEM F/IC
