mazda speed6 oil fliter??
does anyone have pics of where the oil filter is and how it looks like? and can you change it? and how can you change it? thanks
its at the front of the engine. black cap with a silver bolt in the middle.
you will need an oil filter wrench (76mm) and 1/4 Allen Key. basically what i do is loosen the nut with the allen key, turn the cover two full turns, then remove the bolt, let the oil drain, and then remove the cover the rest of the way.
