i havnt had any problems with my CAI and i dont envision having any problems with it. roughly 14000 miles in car.
on that note dose anyone want to buy a MSCAI used?
LMFAO! You are a real peice of work...
More boost and or advanced timing, the colder plugs. would then help, IMo. The Mazda tune, she is a funny thing. every one should pull their plugs, do the free mod while in there and see if you are too hot or cold or rich or lean. You young fella's should know, if you can not wide band the o2. it's all you have to see the air fuel burn result. Again, my North East Coast Old guy Sticky tires opinion
uhhh.... (dunno)
If you do not use a wide band sensor as you modify a car, how can you be sure you are not running into a lean condition under load or at all. Some people can tell you from experience that not having not enough fuel or too lean will do bad things to the internals of a motor. My point should have been that if you do not wide band your car, to be sure it is running safely, you should 'read' your spark plugs. That is what us old folks used to do. To check the spark and fuel results of modifications to the engine. And yes rich is safer, but the car is not running to its potential. Sorry for mix up elie
CAIs are absolutely useless on turboed cars.
all it does is mess with your MAF and sends false readings to the ECU.
this is the fact, and is most likely why mazda doesnt want to be behind a part like that......
....now if u run speed density, or MAP then that's another story. unfortunately MS3s dont.
CAI is a waste of money IMHO. get a good drop in filter and it will give you better results without interfering with MAF readings.
and to those who will puke at me with "dyno this, dyno that"
show me 40-50 back to back runs on a dyne, then we'll talk. consistency is what u want in a street car, NOT being able to have a good run once a week.
I had my car at the dealer today for the fuel pump TSB, and the service manager looked up the intake recall...said it only applies to the ones made in the last 4-5 months. Apparently the "older" ones don't have the same problem, but I wasn't aware that there's been any revision to it?
He said I can keep it and as long as there's no CEL it's fine. Even if they found it was causing a CEL it would be covered by Mazda.
So I guess I'm in the clear.![]()
There are arguments as to the difference in intakes; SRI, CAI, affecting the temps. But all of these flow more volume than the stock. And Turbos love lots of air and no resistance on the backside. All motor a bit different. And yes cooler air is a good thing in a performance vehicle.oh yeah!! Turbo Magazine tackle this same issue and the result was that no matter if you own a turbo or n/a car, lowering the air intake temp will yield more power. Period.
