ECU Re-flash...
I've had a quote for a re-flash 1.3 TS AC & they say i'll get an extra 10bhp ish... 75bhp standard...
Got a quote for my wifes car "Julie71" 1.3 Tamura extra 10bhp ish... 84bhp standard...
Had a look through the EPC & manual to see what the differences are mechanically or electrically
but nothing stands out....
Is this only down to mapping ? Can the 75bhp be taken up to the 94bhp of the re-flashed Tamura ?
Been looking at an aftermarket ECU to fit to the M2, but what controls the main fuel & ignition maps....
Load v Speed to give deg timming & injector.... but what do you generate the load from....
MAP MAF TPS ? trim with Engine Temp, Air Temp, knock, O2....
Controlling EGR, Cam timing, actuator shuttle valve on the inlet ?
Shaun....
Shaun....
