Hello
Does anyone know what the "TA-volume" in the Sound setting meny on the screen is for? When you listen to for example Spotify with Bluetooth connection, the volume tends to be a bit low, if you change to FM radio the sound is a bit higher. I went to the "Settings" and "Sound", you can find a "TA Volume" and a bar you can increase or decrease. If you increase here you hear the sound increases also but after a few seconds it gets lower again. I mean what is that "TA-Volume" for anyway"? I thought that it was a sort of "Master Volume".
Does anyone recognize this?
Best Regards Ola
Best Regards Ola
