Mazda Cargo Concerns - 103 cu. ft.
schex
http://schex.wordpress.com/2009/04/04/mazda-5-cargo-concerns/
Linked from my blog, I'll be driving my 09 Mazda5 from Arizona to Guaymas, Mexico, then on to LA, and finally taking the AlCan up to Delta Junction Alaska, a 5K+ trip.
Cargo space is a concern, and I've come up with a solution, though how it will hold up over the long haul remains to be seen. Since I spent a bit of time here "researching", I thought I'd share.
That is just insane! First I thought you were kidding, until I read your blog. :)
Make sure you blog on your trip and let us know how it holds up.
(wow) thats a lot of stuff. Remember as you load up that the rear hatch is only made of plastic!! I'd be a little concerned about that bag pulling down on the top of the plastic hatch!
It is good the MAZDA5 is not alive. Neighbors might be tempted to call SPCA. :).
Serioiusly, the owner's manual does mention maximum loading of the vehicle.
I'm not sure about cargoes exceeding the length of the vehicle.
Good point on the weight. What is the absolute manufacturer recommended max?
In my case, I believe I have some leeway, since I'm "only" 200 pounds, the wife is half that and the kids are 50 pounds combined. Add the spare tire (40 pounds) and cooler (?30 pounds?) in the interior and we're up to 420 pounds total. The roof box will be carrying about 120 fully loaded, and the saddlebag will probably be about the same. All in all, 660 pounds of additional weight, which really amounts to what 4 full sized adults would weigh.
Nice, never seen that option before, but if it works (naughty).
I hope you've seen this thread, you'll like it and might even find tips (feel free to post more pics as well!):
Mazda5 interior/cargo flexibility photos
Guaymas seems relatively close to the US border yet Mexico now has a good bunch of Mazda dealers, including Sonora, so take note just in case you need anything:
http://www.mazdamexico.com.mx/mexico/distribuidores?state=SON&x=12&y=9
Canada, you should not have an issue finding a Mazda dealer or workshop ;)
And don't forget to keep your car on sight everywhere you travel to and to take the backpack (so to speak) to the hotel with you overnight. The "foreign" license plates (in Canada and Mexico) make it a very attractive target :D
That is what I would check, the roof rails max. weight allowed. It is just attached to the roof, nothing else, and the box on top and the saddlebag hanging in the back are applying forces to the rack in all directions...
For the rest of the car, the weight should be OK, I don't see a major issue (apart from making it heavy and slow ;))
According to the instructions, max weight for roof racks is 165 lbs. I'm not a skilled enough engineer to know if I'm within that tolerance level or if it applies to downward or lateral force, but I figure I'm close enough.
I would not know either but I would follow a simple approach: be sensible when loading the saddlepack, try to keep it as light as possible (avoid the nice-to-take extras) and check often (daily?) how the racks' base is holding up (i.e. the tightening screws seem very small). Again, you are holding a couple of heavy things on the rack and that, along with the drag coefficient at cruise speed, should add good stress to them...
You are serious about this, right?
Would a small trailer not be more aerodynamic, have a lower center of gravity, carry more, be safer (to you and other drivers) and have a higher probability of success?
I realize you have a concern about voiding the warranty, but it looks like you're well on your way to exceeding the vehicle's rear axle weight, and likely gross vehicle weight rating -- which should be far more of a concern than a warranty.
A $100 trailer hitch, a $300 Harbor Freight Trailer, and $100 dollars at Home Depot would net a reasonably large enclosed volume, with only 50 lbs. of tongue weight.
If that's too much, maybe U-Haul will cut a weekly deal on one of these: http://www.uhaul.com/trailers/sport-trailer.jpg
A trailer will add ~300 lbs. of weight that needs to be accelerated and decelerated -- in addition to the cargo, yet all but ~50 lbs. is on the trailer's axle. If you can safely drive what you've shown, a trailer will be no problem.
Good luck.
ok here is my 2 cents
It looks like an over sized shoulder bag with 20 pairs of shoes. It is the most un safe looking system I have ever seen. I assum sharp turns left or right won't send this flying....
It just does not seem safe.
Thanks for the input. And I am definitely serious. There's only one way I'm getting this vehicle and all this stuff back to Alaska.
Regarding the weight, if I were carrying 4 full sized adults then I might be approaching the recommended weight limit of 1020 lbs., but as it stands I should be coming in around 700. Also, the weight does not appear to be concentrated on the rear axle, as it will be distributed evenly if not more to the front inside, more to the front on top, and only 120 lbs on the rear bumper.
I tested this setup the other day with the box and bag attached. I did nothing but take very sharp, overly quick turns with hard braking, and the rear bag didn't seem to move. Heck, I even got the tires spinning/squealing a few times. There are straps on the bottom that you attach under the bumper, and they seem to do a pretty good job of preventing swaying.
Also, the bag will largely be out of the windstream. I don't imagine freeway driving will have much impact on it. Anyway, I've had to resort to these measures due to a rather uncommon situation which most people probably won't find themselves in, but I can at least serve as a guinea pig for anyone who might have similar aspirations. Besides, I've seen much more questionable arrangements in Alaska. This will fit right in.
There's one on the front. Not sure on the regulations however. If it becomes an issue, maybe I could display it in the rear window.
Can't tell, isn't your rear window tinted? If so, probably won't be able to easily see the license plate anyways.
I'm with zoom5, looks unsafe. But if you insist on carrying that much stuff and using that bag, have you considered putting the bag up on the back part of the roof? Therefore the weight is on the roof instead of hanging on straps off the back. Don't know if you can move the cargo box forward a little to give you more room. I think you can remove the antenna. With those straps, you might even be able to route them under the hatchdoor and secure them on the inside back corner cargo latches. Just a thought...
