dugrant153
- Slow
cortez said:And i'd rather have a car that is 200 pounds lighter than 40% stiffer. The difference in weight will be a lot more noticeable.
Doesn't stiffer chassis translate into better cornering?
mattr652 said:I think 2837LB is pretty light for a 2.3L sedan, considering the RSX weighs only 70lbs less.
Curb Weight for the RSX
Manual: 2694 lbs
Automatic: 2771 lbs
Manual (TYPE-S): 2767 lbs (1255 kg)
cortez said:It's not just about the power/acceleration.
My previous daily driver was a WRX. It was pretty fast. It also weighted something like 3200 lbs with driver. You could feel the weight when you tried to take corners fast. You could feel the weight when you used the brakes hard.
