So my stock radiator developed a leak a very long time ago.
But it was a slow leak, I knew where it was coming from and so I just filled it up with a quart of distilled every month or so.
Eventually I ponied up and bought an all aluminum radiator from Ron Davis.
When I emptied the old radiator, the amount of rust in there was alarming. Then with both ends of the engine open and the thermostat removed, I ran my (softened water) hose through the engine, and it took about 10 gallons before it was really clear with no rust.
I went half and half on the Prestone and distilled when I filled her back up, thinking the Prestone would help with the rust. (We don't really need anti-freeze in Phoenix)
Now, it's been a few months with the new coolant and it has piles of rust in the radiator. It's even clumped around the radiator cap. Dark red iron rust.
What could be causing my engine block to be oxidizing so quickly?
If my water pump isn't fouled up beforehand, it's going to eat away a jacket wall, and I'll be seeing white smoke before too long.
I know electrolysis can contribute if you aren't properly grounded, but I've gone through voltage test and while I do see a very small voltage .15V, it doesn't change when the car is on, running, or using accessories.
One thing I have noticed with this car. Is that during the winter months, it produces a very large amount of static electricity, zapping the crap out of me every time I get out of the car, even after very short distances. Whether this is contributing to the rust I have no idea. But other than dragging a grounding strap below the car, I don't have a solution for that either.
