map clamp or BCD ???
funksilver07
2007 Sunlight Silver Mazdaspeed 3 GT
Going to be installing a BCD or map clamp with a MBC on my MS3. I'm not going AP or SB at this point. After some research seems most like the map clamp over the BCD style. More reliability seems likely with this unit, from the threads I've seen. Any thoughts from those using this set up I'd appreciate it. Protege Garage has the JoeP Manual Boost Controller & Split Second Adjustable MAP Clamp for a decent price. They have a Boost Controller (forge) and Boost Cut Defender (ATP) Combo as well. Pricing is comparable so just looking for what will deliver a more consistent set up. Thanks...
of the two combinations we sell the clamp and controller combo is the best one i think. the clamp is adjustable to each vehicle and more stable than the boost cut defender. i like having that kind of precision and control. the boost controller we sell with the clamp is also a more reliable unit than the forge, we've seen a lot of spiking with the forge.
thanks, I appreciate the response... is it worth the extra $20 to go with the Pro-Z as opposed the inline style?
Got the PM thanks...
id also like to know this but id like to know to if the bcd will get the job done just because ****** with the ecu wires scares me a bit. mechanical no prob but ecu ish i know nothin about.
