manuel transmission on my mazda speed 3 2008
Mazda speed 3 2008
My transmission is leaking on top, is it serious and is there a way to check the oil level..
Regards
Richard Vallee
I would be more worried about the cause of the leak. You can easily add more fluid (recomended if you have a leak). Try to pinpoint the leak and go from there. Good luck!
It is coming from the shifter shaft where it enter in the transmission. Do you know if we need to remove the transmission to change it?
