Manual vs Auto sport trans
carz8
I'm thinking about buying a Mazda3 and was trying to find pros and cons on the Manual transmission vs the Auto sport. The auto sport has a manual shifter. Any possitives, neg about this new feature? Leaning towards the auto sport because wife cannot drive 5spd manual. Hoping auto sport shifter will give good acceleration and passing shift when needed.
not so much for passing neeeds just step on the gas an go. Also mazda auto tranny is weak and limits upgrading when it comes to it; although i do like teh auto-sport feature in an automatic. Just because it makes the car that much more fun to drive but a manny is def better. BUT if your in bumper to bumper alot and have some heavy traffic areas with hills you may want to conside an auto.
its such a b**** driving on a hill not that i can talk i live in south FL so we don have many but when im in tally i hate em.
I think the Auto is pretty cool. I love driving stick but I was extremely impressed with the auto. It was smooth and shifted very well. The manual mode was good, but not as good as a true manual.
Here is my opinion. It is based on driving every train combination available in the Mazda3 in the US, take it for what it is worth.
The Mazda3 with the automatic ran well and the manual mode of the transmission worked well. Left to itself, the transmission shifted smoothly and quickly up and down through the gears. When being sporty, manual down shifts under braking for a turn did not upset the car. These down shifts did produce a decent amount of engine braking and should be useful for controlling the cars speed coming down a mountain road. Manual up shifts also worked well. Up or down, the shifts do seem to take a little while once you select the next gear. It also seems that Mazda has built in the same pause in the 1-2 and 2-1 gear changes that are in the Mazda6 auto. These result in a drawn out shift between these gears even in the automatic mode. The sport auto is a decent compromise but not a replacement for a manual.
The manual was excellent, for a standard sedan. The clutch pressure was light with a reasonable amount of feel and easy to manipulate. The shift linkage was short, quick and easy to find the gears. The gearing provides a lot of overlap between gears. 2nd gear could be used down to a very low speed while 3rd allowed you to go as fast as traffic normally would let you. This set up meant that you only needed to use two gears most of the time in the traffic. If you have to stop, then you do need to use first gear. With either engine, the manual worked well. Compared to the 2.3, the 2.0 required more RPM to go quickly but did so with little or no drama.
Although nice and improved, I much prefer the manual to the automatic. If I had to have an automatic, I would get it with the 2.3 liter engine. This is a much happier and responsive set up than the 2.0 auto.
I hope this helps you.
