Lord_Zath said:Where's the sound comin from? If it's coming from beneath your feet, the midpipe is banging against the heat shield. Either pound the heat shield out so it's higher and wider or bend the bars on the exhaust so it rides a little lower...
If it's coming from the tail of the car, it's probably rubbing the bumper. Get some zip-ties or clamps and tie/clamp the hangers in place so the muffler doesn't sway from side-to-side.
wow.. I had all those same problems.. cept the melted bumper thing.spotthedogg said:mine hit the crossmember, then I added Kartboy hangers, then my tip melted my bumper at the track. Vibrates quite a bit too, it also has a leak in the weld ahead of the flex pipe (flame2)
Notorious said:Mine fitted like absolute crap when I first got it. SPD Racing was able to cut it apart and re-weld it correctly.
