carter1551
- 03 Mp5
My car overheated on the freeway a few days ago. It went from operating normally on my work commute to huge plumes of smoke within a second. I pulled over as quickly as I could. My radiator had a major crack and it all gave way at once on my commute. Had mechanic replace it and the hoses and it's still overheats. I managed to get it home using the hot air vent trick.
I swapped the thermostat on my own and it still overheats but the radiator is somehow cool to the touch. After the thermo install I now get no hot air from the vents. The top hose gets hot and the bottom hose doesn't even feel warm. Lastly, the coolant does not seem to cycle at all. I dumped about half capacity in the radiator after the thermo install and filled up the reservoir. It NEVER pulled from the reservoir and the level never seemed to change in the radiator either. I checked the levels after the test drive and then let it idle in the driveway with the rad cap off for 5 minutes and neither affected the coolant level.
Three Possibilities in my Book:
1. I somehow messed up installing the Thermostat and it's stuck closed.
2. The water pump suffered damage from running low or dry when my radiator burst.
3. Head Gasket/Warped Head
HELP ME SORT THIS OUT WITH YOUR THOUGHTS PLEASE!
