magnumP5's RX-7 Build Thread
I drive mine on the street and let it sit in grid @ auto-x's running with the fan on I have never over heated the car. plus with out a shroud you will allow more air flow thru the rad on the track because your not forcing the air thru the shroud.
Interesting; your experience goes against just about everything I've read, haha! I'm curious what your fan area to radiator area ratio is. Even with a 16" fan I have quite a lot of "uncovered" surface area so I'd probably only be utilizing 60-70% with the fan. I get your point about the shroud being a restriction on track. This is why I didn't want a "flat" shroud to begin with. I should make a shroud with "flaps" that open when the car is in motion that are closed when it's stationary.
This is the best pic I have have of the engine bay right now, the car is in storage for the winter.
You can see the cooling fan setup that I have on the car.
I'll snap a picture of my e-fan on my radiator when I get the chance. The FC radiator is a little bigger than the SA/FB one. Marc, do you know the specifications of your radiator (e.g. flow rate, max. current draw)? Mine should be around 3000 ft^3/min at <20 A if I recall correctly. The only other reason I wanted to run some kind of shroud is because I planned on eventually connecting it to some kind of duct that vented out the hood. I was thinking about this more and a shroud shouldn't limit the amount of air going through the radiator. According to conservation of mass so long as the flow isn't supersonic (choked) the area reduction (fan shroud) should only serve to increase the velocity of the flow. This is obviously ignoring pressure effects in the engine bay but it seems to make sense to me. This isn't saying I could get away without a shroud, but I guess what I'm saying is I should do a little more reading.
I'm pretty sure Ivan went to school for that kind of stuff and would be more than happy to help out. Hit him up (fishdonotbounce).
I know. I went to school for it too :) Same undergraduate degree and I have a masters in it too (aerospace engineering) :p
But you don't have to be an engineer to follow understand conservation of mass. Basically whatever amount of fluid enters a volume has to exit. So if the exit area is smaller fhe fluid either moves faster or gets more dense or both. That's the simple explanation but obviously there's a lot more to it.
Doh! I forgot you both basically work for GE...
Regardless, looking forward to what you come up with.
Awesome thread. You're making my want to throw all kinds of money at my RX7..haha
Hahaha, do it! Seriously, the RX-7 serves no practical purpose so I can justify throwing money at it to modify and generally make even more impractical. At least, this is what I tell my wife :)
A little birdie tells me some packages have been delivered. Pictures to follow tonight or tomorrow :D
BOOM!
17x9 +22 Enkei RPF1 in black (special order) with 255/40R17 Dunlop Direzza ZII (successor to the Star Specs):
Comparison of 255/40R17 versus 205/60R15 (what's on the car now). I'm surprised how great the diameter difference is.
Unfortunately the hub rings that came with the wheels don't fit. 59.2 mm != 59.6 mm, thanks Tirerack! Because of that I didn't mess with mounting the wheels, but here's a couple mock up shots.
Rear:
The perspective makes the new wheels seem huge, LOL!
Front.
They still look huge but with the front lip and side skirts I think everything'll even out. I'll probably have to raise the car a bit when all is said and done, which will prove difficult in the rear (already about max'd out). Looks like I'll need to put more preload on the helper springs.
Oh yeah, just a little bit of poke in the front ;) (+20 mm wide fenders coming soon).
Inside clearance is tight in the front but looks doable. I'll check again when the hub rings come in and I put the car back on the ground. Hopefully I'll be able to back off the camber bolts some (added positive camber for last setup) so I can get a little more camber. I'm hoping for -3*/-2* F/R. The inside clearance in the rear will be just fine but I'll likely be massaging the fenders a bit. I'm quite pleased with how everything turned out. I know a lot of people don't like black wheels but I think they work on this car (everything is red/black).
BOOM!
Rear:
Front.
Nice wheels love the color.....Sorry Larry!!!! hahahahahahahahahahahahahahaha
rpf1's....just sexy.
And concave! Sorry, but I've never had concave wheels before and I'm excited :)
Looking really good! And loving the meaty tires.
You're telling me! And I thought my previous setup was "meaty." The only thing now is my brakes look TINY! Unfortunately I don't think I could ever upgrade to a BBK as I think most interfere with the concave RPF1's. Oh well...
They're a lot glossier than I thought they would be. I think they'll match up nicely with the black taillight bezels and I'm planning on painting some/all of the splitter black as well. The only thing is the finish doesn't seem to be too durable. I slipped taking the wheel off the front spindle (it moved because there's no steering rack!) and that was enough to scratch off the pain in the back in a few places. This is also the first set of RPF1's I've owned that don't say "Enkei" all over them. If it ends up bugging me I know I can find red stickers for them.
Looks good! One of my all time favorite rims. Black and red works really well on FC's. Mine will be keeping the black and red theme too, but it's not nearly as awesome a car as yours!
If you ever have a questions about fitting wheels or tires on the FC let me know as I've done quite a bit of research on it. It's hard to find good information now due to the drift/stretched tire scene.
just read all 68 pages! insane build!!
Congrats on the baby!
Thanks! You have a lot more patience than me if you read through all my rambling in one sitting!
Damn thems some meaty tires!
And I thought the 215/40R17 on my old Protege5 was meaty! It's going to be a b**** to turn the front wheels without P/S now!
