Weekend progress:
The last of my ARP hardware came in:
I finally got around to stripping the anodized coating from the throttle body pieces. Stripped (left) and unstripped (right):
Everything stripped:
Polished and reassembled throttble body. Everything is now bagged up and waiting for final instal:
I also got a lot of painting done. The misc. brackets and things are 90% done; sorry no pictures though. Intermediate housings painted:
For some reason the intermediate housings came out very glossy. I changed my painting style, which seemed to lay the paint on a little thicker and give a nicer fnish, so perhaps that explains it.
In other news I bought most of the materiel needed to make the fiberglass fan shroud: resin, hardener, glass mat, filler, more hardener, and some 1/2" MDF and fleece for the "buck." I still need to pick up a roller, wax, and PVA becase I don't want the fleece to be part of the final product.
On the ducting side of things I picked up some 1/4" foam board for mock ups. The more I think about it the more I want to slightly relocate the oil cooler. Right now the oil cooler and radiator are in "series" but air can flow over the top of the oil cooler, bypassing it altogether. What I'm thinking about doing is pushing the oil cooler back and laying it down, sealing against the bottom of the radiator for a "V-mount" setup. This way air that enters the front of the car has to pass through the radiator into the engine bay or through the oil cooler exiting underneath the car (will require cutting a hole in the undertray).
