Lowering springs with stock shocks?
miatafied
Contributor
Mazda5/kidhauler - Miata/fun car
Just wondering if all of you with lowered springs have gone with aftermarket shocks as well. I was under the impression that shorter stiffer springs require better than stock shocks to pair up.
well I have been running sportlines for about 5 months now with stock struts and have no problems. I of course will be getting new shocks soon or maybe some coilovers, but if you want to drop your car you do not NEED new struts
Yea what he said, I've been running on the eibachs for a yr now on the factory struts with no problem.
Anybody on Tein s-techs?
I was under the same impression...shorter/stiffer springs will blow out stock shocks.
I've heard people say that but I can't think of a single reason why it would be true. The only effect it should have is that the shocks won't travel as much and will rest in a different position. That shouldn't have any detrimental effects, at all.
The guy at the garage that installed mine said the only reason they will wear faster is less travel area, so it is wearing at a smaller area more frequently, but even if you get new shocks, it wont change travel distance much.
exactly.... with lowering your car you are just decreasing the travel area that the shock goes over....its not like a shock is a linear bearing and needs to circulate the ball bearings for optimum performance... all the shock is is a cylinder in a tube with some lube and a seal (put simply) ... by decreasing the travel area of the cylinder and possibly a faster rebound rate b/c of springs you will see some faster wear in that area, the wear rate should only increase by a small amount....aftermarket shocks have different lubricants and design to improve wear rates for lowered cars so when your stockers do go i would deffinatly look into an aftermarket shock....
Anyone know of aftermarket damper options? I have been looking but no success. I am not intrested in coilovers at this point. I already have the Eibach pro-kit installed so I just want to upgrade the dampers to adjustable and better valving items.
I am running s techs on my Lx , I am now at the point that i need to replace the struts I have 130 k ( 80,000 miles )on the stock struts . I would considered this normal wear for struts ,so go ahead and lower your car . If you are a hard driver your struts will wear out faster . It is usually the rebound that will wear out first , The stock struts arnt designed to control the extra pressure that the teins put on the strut
mazda speed are the only af struts out there so far.... they aren't cheap either its like 450 for all 4 or something like that...
Anyone running these around here to give a good synopsis of the proformance difference? Any Idea who has them for sale?
Dont forget Tokico HP's ,Tokico Illuminas as well as KYB . You can also look at Koni and billsten
I'm running S-Tech and Mazdaspeed Sport dampers on my 3. The ride is pretty stiff as expected....but handling is great! Here are some pics
I have Eibachs, no problems with struts as of yet(at least 1year old), very stiff ride though. I have replaced the rear, and now my front sway bar bushings are bad and need replacing, unsure if this is related to the lowering springs...
they don't make those for the mazda 3 yet wise ass. look where you're typing
Just bumping an old thread to see if anyone out there has anymore info on aftermarket shocks that i havent heard? Or if anyone with lowering springs has had any stock shock problems?
