2013~2016 Low RPM triggering P2262 "Turbo Boost Pressure Not Detected - Mechanical"
cx5fun
The car triggers the P2262 code when it goes to low RPM, (<1500) where the boost isn't working anyway as far as i know.
Has any1 had a similar issue before, and if so, how did you fix it :) ...
Edit, turns out it was indeed a faulty map sensor, i've been it for 200km now with stops and slow downs and it hasn't came up since :D
Hi so p2262 was the map sensor? Not the exhaust sensor ? How may I ask you cane about finding this out ? I recently cleaner mine but maybe it was too far gone it was badly clogged I'd cleaned it wwll carefully though how does it drive now better yes ? Thanks
