[font=Arial, sans-serif]Lotus Europa S Specifications and Technical Details[/font]
<DL><DD><TABLE borderColor=#000000 height=1059 cellSpacing=0 cellPadding=0 width=535 border=1><COLGROUP><COL width=57></COL><COL width=199></COL><TBODY><TR vAlign=top><TD width="22%" height=39>[font=Arial, sans-serif]Powertrain[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Mid-mounted, transverse, 1998cc turbo charged DOHC engine, with a 6-speed
transmission.[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Max Power[/font]
</TD><TD width="78%">[font=Arial, sans-serif]200 hp (149 aKW) (203 PS) @ 5400 rpm[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Max Torque[/font]
</TD><TD width="78%">[font=Arial, sans-serif]194 lbft (263 Nm) @ 4200 rpm[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Power to weight ratio[/font]
</TD><TD width="78%">[font=Arial, sans-serif]201 hp/t (149 kW/t, 204 PS/t )[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Specific power output[/font]
</TD><TD width="78%">[font=Arial, sans-serif]100 hp/ (75 kW/ , 102 PS/ )[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=20>[font=Arial, sans-serif]Emissions control[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Euro IV emissions compliant with full On-Board Diagnostics (OBD)[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=31>[font=Arial, sans-serif]Suspension[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Fully independent sport suspension utilising unequal length wishbones, Bilstein mono [/font]
[font=Arial, sans-serif]tube gas damper, Eibach coaxial coil spring at each corner and front anti-roll bar.[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=31>[font=Arial, sans-serif]Chassis[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Lotus designed lightweight structure of epoxy bonded aluminium alloy extrusions and[/font]
[font=Arial, sans-serif]lightweight steel rear subframe.[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Steering[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Solidly mounted mechanical rack and pinion steering box with 2.8 turns lock-to-lock.[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=47>[font=Arial, sans-serif]Brakes[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Servo-assisted, 4-channel Anti-lock Braking System (ABS) with Lotus/AP-Racing twin [/font]
[font=Arial, sans-serif]piston fixed aluminium alloy front brake callipers, Brembo single-piston sliding rear[/font]
[font=Arial, sans-serif]callipers and 288 mm diameter, 26 mm thick front and rear cast-iron ventilated discs.[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Wheels[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Unique lightweight wheels (17 front and rear)[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=55>[font=Arial, sans-serif]Tyres[/font]
[font=Arial, sans-serif]Performance Figures[/font]
[font=Arial, sans-serif]0-60 mph[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Bridgestone Potenza 175/55 R17 (front) 225/45 R17 (rear)[/font]
[font=Arial, sans-serif]5.5 s approx[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]0-100 mph[/font]
</TD><TD width="78%">[font=Arial, sans-serif]14.0 s approx[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=17>[font=Arial, sans-serif]Maximum speed[/font]
</TD><TD width="78%">[font=Arial, sans-serif]140 mph (225 km/h) approx[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=31>[font=Arial, sans-serif]Fuel consumption [/font]
[font=Arial, sans-serif]extra urban[/font]
</TD><TD width="78%">[font=Arial, sans-serif]38.9 mpg (7.26 l/100km)[/font]
[font=Arial, sans-serif]combined[/font]
</TD><TD width="78%">[font=Arial, sans-serif]30.4 mpg (9.29 /100 km)[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=22>[font=Arial, sans-serif]C02 emissions[/font]
</TD><TD width="78%">[font=Arial, sans-serif]220 g/km[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Fuel tank capacity[/font]
</TD><TD width="78%">[font=Arial, sans-serif]43.5 litres ( 9.6 gal (UK))[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=55>[font=Arial, sans-serif]Luggage capacity[/font]
[font=Arial, sans-serif]Dimensions[/font]
[font=Arial, sans-serif]Wheelbase[/font]
</TD><TD width="78%">[font=Arial, sans-serif]154 litres - 50 kg[/font]
[font=Arial, sans-serif]2330 mm[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Track[/font]
</TD><TD width="78%">[font=Arial, sans-serif]1457 mm (front) 1490 mm (rear)[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Length[/font]
</TD><TD width="78%">[font=Arial, sans-serif]3900 mm approx[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=16>[font=Arial, sans-serif]Width[/font]
</TD><TD width="78%">[font=Arial, sans-serif]1714 mm (1850 mm, door mirrors included)[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=16>[font=Arial, sans-serif]Height[/font]
</TD><TD width="78%">[font=Arial, sans-serif]1120 mm[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Weight distribution[/font]
</TD><TD width="78%">[font=Arial, sans-serif]38% Front - 62% Rear[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=25>[font=Arial, sans-serif]Vehicle mass - unladen[/font]
[font=Arial, sans-serif]Interior[/font]
</TD><TD width="78%">[font=Arial, sans-serif]995 kg (running order, full tank of fuel )[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=27>[font=Arial, sans-serif]Specification[/font]
</TD><TD width="78%">[font=Arial, sans-serif]ProBax design leather trimmed seats (Black or Black and Tan)[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Driver and passenger airbags[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Leather interior[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Black plain leather sun-visors[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Black perforated leather, gear-lever and handbrake gaiters[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Electric windows[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Central door locking[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Polished aluminium heater control knobs, handbrake handle and air vent trims[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]In Car Entertainment[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Satellite navigation unit, CD/MP3 player and radio[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Security[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Immobiliser and remote activated alarm[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=18>[font=Arial, sans-serif]Other[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Auxiliary front lights (standard)[/font]
</TD></TR><TR vAlign=top><TD width="22%" height=17>[font=Arial, sans-serif]Protection[/font]
</TD><TD width="78%">[font=Arial, sans-serif]Front Bumper paint chip protection film[/font]
</TD></TR></TBODY></TABLE></DD></DL>
