heres a summary of the control specs if anyone is interested:
Usage manual
3.1 Supported iPods
All iPods 2G and up (latest firmware recommended)
3.2 Basic features
GROM-IPOD adapter has 2 modes it can operate in.
3.2.1 Simple mode: iPod can be controlled via clicking wheel and stereo controls. Information on
car stereo is not accurate and does not represent the actual song. There is no need to
prepare your iPod to play in this mode. Simple mode is always selectable by choosing CD1
(DISK1) from the car stereo. To switch to advanced mode just select any disk that is
different from 1
3.2.2 Advanced mode: iPod is locked for control and only operated via car stereo buttons. In this
mode all data is synced between stereo and iPod. Allow you to see song text info (where
available) and other information such as track number, playlist number etc. In order to use
this mode you have to prepare iPod as explained below. Advanced mode is always on for
disks 2-9. To switch to simple mode just select DISK 1
3.3 Supported operations in Simple Mode
In simple mode iPod behaves in the usual fashion when click wheel and display is functional. The
following control is possible from the car stereo:
- Next track
When pressed on car stereo, iPod will jump to the next song and car stereo track number will
increase by 1.
- Previous track
When pressed on car stereo, iPod will jump to the previous song and car stereo track number
will decrease by 1
- Fast Forward
When pressed iPod will start rewinding current track forward
- Fast Reverse
When pressed iPod will start rewinding current track backward
- Play/Pause
When stereo is turned into CD changer mode the iPod will automatically start playing. Upon
turning stereo off or switching to another source (FM,AM etc) it will pause current track
- Disk Change
When changing disk the iPod will switch to Advanced Mode
All information displayed in simple mode is not related to the song currently playing. The display will
show: DISK 1 TRACK xx TIME 00:00
iPod
- 5
rev 2.0
Track information can change from 00-99.
3.4 Supported operations in Advanced Mode
In advanced mode iPod controls will be locked and the following operations will be supported:
- Next track
represent song number in a current playlist
- Previous track
will represent song number in a current playlist
- Fast Forward
When pressed iPod will start rewinding current track forward. Time on car stereo will represent
actual position within the audio track
- Fast Reverse
When pressed iPod will start rewinding current track backward. Time on car stereo will
represent actual position within the audio track
- Play/Pause
When stereo is turned into CD changer mode the iPod will automatically start playing in simple
mode at the last position it was left.
- Scan
Allow to skip tracks by 10 when set. Next track will jump to current track+10. Previous track will
jump to current track-10. It is helpful to skip the whole album (usually ~10 songs)
- Disk Change
When you select Disk 2-9, iPod will stay in Advanced Mode and will resume last playing track in
a playlist. Once DISK 1 is selected, iPod will switch over to Simple Mode
- Mix/Random
When turned on it will allow to play songs in a shuffle mode through the whole playlist. The track
enumeration will start from 1. When switched off, track enumeration will be restored to the real
order in the playlist.
- Repeat
When turned on, will play first track in the playlist after the last track is played.
3.5 Playlists set up for advanced mode
To use iPod in Advanced Mode you have to define up to 8 playlists (on most stereos only 5).
There is no need to name playlists in a certain way. The only thing that matters is the position of the
playlist on your iPod. All playlists are enumerated from the very beginning of the list and numbers are
assigned according to the position.
For instance if you have playlists defined like:
Andys songs
Disco dance
iPod
- 6
rev 2.0
Favorites
House rhythms
Andys songs will be mapped to the disk 2, Disco dance will be on disk 3 and so on.
Therefore selecting DISK 2 on car stereo will play Andys songs playlist, DISK 3 will select Disco
songs and so on.
