location of egt probe on msp any pics???
The egt should be placed half the diameter of the primary tube of the exhaust manifold away from the cylinder head. It doesn't matter what type of car.
tanks for answering any pics
You should drill a hole 2 inches from the cyl. head on the 1st cyl. nearest to the throttle body(on the exhaust manifod). I suggest using grease on the drill and the tap to minimise metal in the exhaust manifold (to prevent turbo damage). If you are not sure on how to do this , i suggest you to go to the nearest speed shop .
Also, when you tap it, have the car running, that way the exhaust pulls the shavings out.
And the shaving will not damage the turbo ?? anybody can confirm this ?? I think it's better to uninstall it.
Yes , the best would be to uninstall it , but it can be leaved in place , but the metal chips will go trought the turbo and into the Cat ....
bump, for interest in pics for install in manifold. as far as install in midpipe, i thought it wasn't accurate if it's installed after turbo?????
yes , it's better than nothing . But I still want to see a msp with it. I don't belive it, we are over 16000 user on this forum and any body have the pic I want.
off topic but ......
Btw turbobass I think we can speak in french we are both from qubec. Es ce que je me trompe ???? Je suis aussi sur le forum CPQ et toi ??
Turbobass said:
I've got a Celica with egt .... want the pics anyway ?
B/C I would like to see (eek2) were he put it. I have one to install on my msp and I wonder How I will do it and were I should drill the hole ????
BlkZoomZoom said:
Why do you want pics so bad?
i spoke with the main mechanic at SPD about the placement of the EGT. He pointed out to me another location to install the sensor (the J-pipe). What I noticed is that the stock J-pipe of the MSP acutally has a bunge with bolt covering it up. I don't know if it will work, but try plugging in the sensor there. Any thoughts on this?
