little help?
alleeclan
Hello , im new to this forum thing so bare with me. i have a 94 626 mazda v6-automatic with issues , hopefully someone has an idea on which direction to look , here goes ......
something is causing the fuel and the distributor to shut off intermittenly. when it is running it will not die on you but when you shut it off and let it sit for a while this happens . when it will start you can shut it off and it will start right back up . it might start after sitting for a day sometimes it has to sit for a week or so before it will start again. i did replace the ecm , and the distributor with no change . any help would be great. this is my daughters car and she has already mentioned something about gas and a match !!!!!!
Simple way to test your car is do paper clip test in the dignose box. This advice is very helpful & can save you alot of money.
