Limited powertrain warranty
fivepak
2013 CX-5 GX 6spd
Hey all,
First time Mazda owner and new to the forum. I just purchased a cpo Cx5 that includes 7yr/140k limited powertrain warranty. Unfortunately I wasn't able to get a clear answer from the dealership on what parts are covered under this limited powertrain warranty. Does anyone have a list of what this warranty actually covers? I find it a bit suspicious that Mazda promotes this as reason to buy a CPO yet there's no pamphlet describing what's covered.
My previous experience has been with Vw cpo vehicles and there's a nice list of all the items covered by their 2yr/40k warranty. Wish Mazda had something similar...
Any input would be greatly appreciated.
Sent from my HTC One_M8 using Tapatalk
Just google it, come up right there.
Powertrain Warranty Parts List
The listed below are the powertrain components covered under the Powertrain Limited Warranty:
Engine
Cylinder Block, Cylinder Head, and All Internal Lubricated Parts (Piston engines)
Rotor Housing and All Internal Parts (Rotary engines)
Timing gears
Timing chain/belt and tensioner
Timing chain/belt front cover and gaskets
Flywheel
Valve Covers
Oil Pan
Oil Pump
Intake Manifold
Exhaust Manifold
Engine Mounts
Turbocharger Housing and All Internal Lubricated Parts
Supercharger Housing and All Internal Lubricated Parts
Powertrain Control Module
Water Pump and Gasket
Thermostat
Fuel Pump
Seals and Gaskets
Freeze Plugs were not added
Transmission and Transaxle
Transmission Case and All Internal Parts
Torque converter
Clutch Pressure Plate
Transmission Mounts
Transfer Case and All Internal Parts
Transmission/Transaxle Control Module
Front/Rear Drive System
Final Drive Housing & all Internally Lubricated Parts
Manual and Automatic Hub (4X4)
Front Wheel Hubs and Bearings (FWD Transaxles)
Rear Axle Housing & all Internally Lubricated Parts
Axle/Drive Shafts
Propeller shaft (RWD and AWD only)
Universal Joints
Constant Velocity Joints
Rear Axle/Hub Bearings (RWD and AWD only)
Seals and Gaskets
Thanks dude. The first thing I did was run that search on Google and all I got was a bunch of links to dealerships cpo programs. I'm in Canada...
Canada may be different. Warranty programs vary widely from country to country...
Sounds to me like the warranty means "Limited to the powertrain".
Meaning physical hardware that makes it go.
ie. the electronic solenoid in the transmission isn't covered, but the clutches are.
