phunky.buddha
Booga Booga?
- DFW TX
- No mo MZ5 want MX5
The design of this wheel suggests it could handle the CX-5's weight. Its a good alternative if you can find some locally. Also, my cousin has an EVO 8 with 17inch forged BBS wheels. I believe they fit but too bad he ain't selling them to me.
Considering that the CX-5 GT curbs in at 3200 pounds and my Mazda 5's curb weight is around 3500 pounds, I think you'll be ok with MX-5 wheels on a CX-5. I've flogged the crap out of my 5 with the roof box overloaded and every seat filled plus stuffed with cargo inside- so the CX-5 will be just fine on a set of these. Most OEM wheels are way tougher than they need to be anyway so that the factory doesn't have to deal with broken wheels coming back and being a safety issue.
As long as you stick with a 17, 18,19 inch rim, you will likely not see any change in the mpg at all. If you have a 17inch rim, go with 65 tire, 18 inch 60 tire, 19 inch 55 tire. In my opinion a 8 inch rim with a 235 finishes the look as the the 7 inch rim and a 225 tire is too narrow......which is the only thing I did not like about the CX-5.....the stance was too narrow for a vehicle which such a muscular shape. The Kia Sportage top model sits on 235/60/18.....all just my opinion though.....do what you think looks best or feels good too you.
235 on a 7" wheel, especially on the height that would fit the CX-5 wouldn't be bad at all in terms of profile. I'm running 235/45 on my 17x7 and the sidewall is only slightly pinched. The CX-5 would be a good bit taller, so probably 235/60 or 235/65, which both actually specify a 7" wide wheel as the measure wheel from most manufacturers. It would look "right" on a 7.
