light 17"
OZ Superleggera... +45 offset (17x7), 15.2 Lbs, $263.99 at Tirerack. They also have them in 17x8
GREATG said:
Or you could stopping f**king around and go straight for the top of the pile, SSR Comps 17 X 7.5 (13.0lbs) for $500 a piece at the tire rack.
omg, those rims are hotT
5Zigen FN01-C's in 17X7 are 15.5lbs. Konig Holes in 17X7 are 16lbs. Both rims have the proper offest for a P5/MSP.
mazdaspeedchick said:
GB goin on for the Rota attacks 18lbs for the 17in
http://www.msprotege.com/forum/showthread.php?t=73315
These Rota's are 17x7.5" - would the stock 215/45's work on these? I know the 215's will work on a 17x7 rim, since that's what the stock rims are, but does the extra 1/2" of width mean I'd have to move to a 225 section width tire?
Another question - I've seen people with problems regarding rubbing with a 225 tire on the stock rim, and the stock rims have +55 offset. How would a wheel with +43 or even +45 offset fit without rubbing?
Alex
Quik89Si said:
Those wheels go for $193 each on www.discounttiredirect.com - and they weigh about 16lbs each. Compared to ~25? lbs for the RH's, that's not bad at all...
They have +43 offset, so they should fit a MSP no problem...
Alex
I only see the 42mm offset, where do you see a 43?
Actually, if you look at www.5zigenusa.com, you can see that they come in two offsets - the +42 or +43, whichever it is, and then a +48, which would probably fit the MSP much better without rolling any fenders or worrying about rubbing.
Alex
