tarapajero1
- Mazda CX-5
Some websites recommend a pair of load resistors for LED turn signal lights. Will it work or burn out faster if I don't get load resistors?
That's theoretically (possibly) true. But there are some realities of physics here. Even top bin LEDs have to be driven hard and so put out a lot of heat. Accordingly they NEED big heatsinks. There's not enough space in a reflector designed for standard bulbs to fit high-current LEDs, and the requisite heatsink, through the hole. Thus, the LEDs are underdriven and underperform. Plus the light that they DO give is badly scattered by a reflector system not designed for multiple point sources, so the results are not good. Don't believe the marketing mis-info.Your statement may be true for the lower end of the LED cost spectrum and the "brightest" automotive LED replacements 2-3 years ago. Fortunately LED's have come a long way... The higher end LED's with advanced SMD's like Tritons and CREE's can be significantly brighter than incandescent bulbs they replace.
