Led tail light bulbs causing ERROR
I am thinking about replacing my tail light bulbs with LED and I was wondering whether the LED bulbs will trigger error message on dashboard?
And if it will, is there anyway that I can work around this issue?
if they cause a hyper-flash, then likely, yes it will.
you can avoid this by getting expensive bulbs which have built-in load resistors, or installing your own load resistors on the circuit. The down side there is that if you have one LED and one non-LED bulb on the same circuit, you may or may not find out about it, depending on how the car is wired, because the resistor will trick the car into not seeing the problem.
