LED fog light project
Int3grity
07 Cx-7 Liquid Platinum
I am planning on making my own s6 style led lights for the fog area.
I will be using acrylyc plexi for the lens and flexible 16 gauge long strips of sheet metal. Following directions from a guide someone made at the VWaudi forums. Now my main question here is
I would like to setup a 12v direct path to the battery and add a push style mazda oem switch to turn on the lights. But is it also possible to add a third wire and use it as a turn signal relay as well? if so how would you go about doing it?
Its gotta be possible if you wire it to the existing turn signal relay instead of direct to the batt. I dont think the S6 lights flash though when the turn signal is on, do they? Where did you get the LEDs? I replaced my interiors with HyperWhite LED bulbs, but this would be a fun project. Bet little Wedge type bulbs would perfect to somehow pop into the light enclosure.
Integrity... pm me with email and I will send you the directions I made for my fog light kits. Same thing should apply except you are running a switch in the circuit. I have my wife's setup to turn on with the parking lights and run as turn signals.
Why don't you share this info in public? This is what boards are about.
If you think that you infringe copyright change your guide to be legit.
Banjo
Banjo
What? Infringe what copyright? And the info is posted somewhere, that's where I got it from. Simple wiring of a relay, jeez don't get all bent out of shape. The hard part, as I'm sure he'll learn is actually making the LED housing and lens so that it looks like an OEM piece.
