I am planning on making my own s6 style led lights for the fog area.
I will be using acrylyc plexi for the lens and flexible 16 gauge long strips of sheet metal. Following directions from a guide someone made at the VWaudi forums. Now my main question here is
I would like to setup a 12v direct path to the battery and add a push style mazda oem switch to turn on the lights. But is it also possible to add a third wire and use it as a turn signal relay as well? if so how would you go about doing it?
